60PM010 - 60 mm Planetary Gearhead
The 60PM010 planetary gearhead offers true planetary performance in a high torque, low backlash design with excellent shaft loading characteristics. Primetric Planetary gearheads are offered as standard to fit NEMA motor flanges. They can be machined to mount to almost any motor. Please supply the drawing of your motor when ordering.
Available in 48 hour lead time
High radial and axial shaft loading capacity
True planetary design
Low start-up torque
High torque capability
Compact design
Popular metric output shaft and front bracket design
Rigid stepped output shaft design with metric key and threaded mounting hole
Metric and NEMA motor mounting available
Other ratios available in 2-4 week lead time: 3, 4, 5, 5.5, 7
Company Applied Motion
Part Number 60pm010_60_mm_planetary_gear
Backlash 6 arc-min
Efficiency [%] 90%
Frame Size 60 mm
Inertia 9.393E-04 oz-in-sec2
Input Speed 6500 rpm max
IP Rating No
Low Backlash NA
Operating Temperature No
Part Number 60PM010
Ratio 10:1
Service Life > 20,000 hours
Shaft Diameter No
Torque E Stop No
Torque Max Accel 179 in-lb
Torque Nominal 119 in-lb
