34PL005.5 - NEMA 34 Planetary Gearhead
The 34PL005.5 planetary gearhead offers true planetary performance in a high torque, low backlash design. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
Available in 48 hour lead time
True planetary design
Low backlash design
High strength steels
High shaft loading capacity
Sealed ball bearings
Heat treated gears
High efficiency design
Other ratios available in 2-4 week lead time: 3, 5, 7
Company Applied Motion
Part Number 34pl005_5_nema_34_planetary
Backlash 6 arc-min
Efficiency [%] 90%
Frame Size NEMA 34
Inertia 1.585E-03 oz-in-sec2
Input Speed 6500 rpm max
IP Rating No
Low Backlash 3 arc-min
Operating Temperature -50 to 120 C
Part Number 34PL005.5
Ratio 5.5:1
Service Life > 10,000 hours
Shaft Diameter 19.05 mm (0.750 inch)
Torque E Stop No
Torque Max Accel 1740 in-lb
Torque Nominal 1113 in-lb
