34PL004 - NEMA 34 Planetary Gearhead
The 34PL004 planetary gearhead offers true planetary performance in a high torque, low backlash design. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
Available in 48 hour lead time
True planetary design
Low backlash design
High strength steels
High shaft loading capacity
Sealed ball bearings
Heat treated gears
High efficiency design
Other ratios available in 2-4 week lead time: 3, 5, 7
Company Applied Motion
Part Number 34pl004_nema_34_planetary_ge
Backlash 6 arc-min
Efficiency [%] 90%
Frame Size NEMA 34
Inertia 2.833E-03 oz-in-sec2
Input Speed 6500 rpm max
IP Rating No
Low Backlash 3 arc-min
Operating Temperature -50 to 120 C
Part Number 34PL004
Ratio 4:1
Service Life > 10,000 hours
Shaft Diameter 19.05 mm (0.750 inch)
Torque E Stop No
Torque Max Accel 1905 in-lb
Torque Nominal 1219 in-lb
