26BC 6A 110 .101
26BC 6A 110 .101
The 26BC brushless DC slotless motor utilizes a self-supporting cylindrical ironless coil made in the same winding technique as our ironless DC motors. The 26BC mini motor offers long life, excellent speed and position control and smooth rotation. The integrated electronics features direction selection, start/stop function and output speed signal.
Compact design
Slotless
2 poles
Low iron losses at high speed
High efficiency
3 phases
Integrated electronics
Shaft lengths
Special coils
Cables and connectors
Value added mounting
Part Number 26BC6A110.101_slotless
Diameter, in 1.06
Length, in 1.27
Nominal Voltage, Volt 15.0
Optimization Speed No
No-Load Speed, rpm No
Typical No-Load Current, mA 120
Max continuous mechanical power (@ 25°C) No
Max continuous Current, A 0.4
Max Continuous Torque,oz-in 0.62
Back-EMF Constant, V/1000 rpm 1.40
Torque Constant, oz-in/A 1.9
Motor constant k/R½, oz-in/W½ 0.45
Internal resistance - phase to phase, Ohm 17.60
Line to Line resistance at connectors, Ohm 17.60
Inductance - phase to phase, mH 1.65
Mechanical Time Constant, ms 92.0
Electrical time constant, ms 0.09
Max motor speed, rpm No
Ambient working temperature range, °F No
Ambient storage temperature range, °F No
Ball bearings preload, N 5.0
Axial static force without shaft support, N 120
Max winding temperature, °F 257, 257
Thermal Resistance, °C/W 14
Thermal Time Constant, °C/W No
Weight Oz 2.54
Rotor Inertia, gcm² 9.4
Typical Housing Material No
Hall Sensor Elecrical Phasing, electrical° No
Motor Regulation R/k², 10³/Nms 98.02
Company Portescap
