26BC 3C 109P .101
26BC 3C 109P .101
The 26BC brushless slotless motor utilizes a self-supporting cylindrical ironless coil made in the same winding technique as our ironless DC motors. The 26BC mini motors offers long life, excellent speed and position control and smooth rotation.
Compact design
Slotless
2 poles
Compact design
Low iron losses at high speed
High efficiency
3 phases
Shaft length
Special coil
Cable and connector
Value addtion mounting
Part Number 26BC3C109P.101_slotless
Diameter, in 1.06
Length, in 1.27
Nominal Voltage, Volt 12.0
Optimization Speed No
No-Load Speed, rpm No
Typical No-Load Current, mA No
Max continuous mechanical power (@ 25°C) No
Max continuous Current, A 0.8
Max Continuous Torque,oz-in 0.99
Back-EMF Constant, V/1000 rpm 0.73
Torque Constant, oz-in/A 0.99
Motor constant k/R½, oz-in/W½ 0.44
Internal resistance - phase to phase, Ohm 5
Line to Line resistance at connectors, Ohm 5
Inductance - phase to phase, mH 3.80
Mechanical Time Constant, ms 95.0
Electrical time constant, ms 0.76
Max motor speed, rpm No
Ambient working temperature range, °F No
Ambient storage temperature range, °F No
Ball bearings preload, N 5.0
Axial static force without shaft support, N 120
Max winding temperature, °F 257, 257
Thermal Resistance, °C/W 14
Thermal Time Constant, °C/W No
Weight Oz 2.54
Rotor Inertia, gcm² 9.4
Typical Housing Material No
Hall Sensor Elecrical Phasing, electrical° No
Motor Regulation R/k², 10³/Nms 102.04
Company Portescap
