22ECS45 10B 18 .01
22ECS45 10B 18 .01
Part of our ULTRA EC series, the 22ECS45 brushless DC slotless motor features a new patented magnetic design. The 22ECS45 miniature motor offers long life, excellent speed capability and smooth rotation.
With hall sensors
Slotless
2 poles
Compact design
Low iron losses at high speed
High efficiency
New patent pending coil design
High power density pacakge
3 phases
High speed optimized
Shaft lengths
Special coils
Cables and connectors
Magnets / lamination grade
Special mounting holes pattern
Value addtion mounting
Thermal sensor removal
Part Number 22ECS4510B18.01_ultra_ec
Diameter, in 0.90
Length, in 1.77
Nominal Voltage, Volt 24.0, 24.0
Optimization Speed No
No-Load Speed, rpm No
Typical No-Load Current, mA 300
Max continuous mechanical power (@ 25°C) 120.0
Max continuous Current, A 8.2
Max Continuous Torque,oz-in 3.80
Back-EMF Constant, V/1000 rpm 0.34
Torque Constant, oz-in/A 0.47
Motor constant k/R½, oz-in/W½ 1.56
Internal resistance - phase to phase, Ohm 0.09
Line to Line resistance at connectors, Ohm 0.10
Inductance - phase to phase, mH 0.02
Mechanical Time Constant, ms 1.9
Electrical time constant, ms 0.13
Max motor speed, rpm No
Ambient working temperature range, °F No
Ambient storage temperature range, °F No
Ball bearings preload, N 5.5
Axial static force without shaft support, N 34
Max winding temperature, °F 257, 257
Thermal Resistance, °C/W No
Thermal Time Constant, °C/W 660
Weight Oz 3.88
Rotor Inertia, gcm² 2.3
Typical Housing Material No
Hall Sensor Elecrical Phasing, electrical° 120
Motor Regulation R/k², 10³/Nms 8.50
Company Portescap
