22ECP60 8B 90
22ECP60 8B 90
The ECP line of miniature motors are ultra cost optimized without compromising on premium performance. The 22ECP60 provides high continuous and peak torques with limited core losses over a wide range of working speeds, and without friction or brush wear. With the 22ECP60, you can get the right balance between torque and speed to suit most applications
2 poles slotless
With or without hall sensors
2 standard lengths available
Proprietary coil design, high efficiency
Maximized performance/price ratio
Connector
Different coil impedance
Shaft lengths
Part Number 22ECP608B90_slotless
Diameter, in 0.87
Length, in 2.36
Nominal Voltage, Volt 24.0, 24.0
Optimization Speed 0
No-Load Speed, rpm No
Typical No-Load Current, mA 40
Max continuous mechanical power (@ 25°C) 120.0
Max continuous Current, A 1.8
Max Continuous Torque,oz-in 7.20
Back-EMF Constant, V/1000 rpm 2.96
Torque Constant, oz-in/A 3.99
Motor constant k/R½, oz-in/W½ 2.59
Internal resistance - phase to phase, Ohm 2.38
Line to Line resistance at connectors, Ohm 2.47
Inductance - phase to phase, mH 0.47
Mechanical Time Constant, ms 1.1
Electrical time constant, ms 0.20
Max motor speed, rpm No
Ambient working temperature range, °F No
Ambient storage temperature range, °F No
Ball bearings preload, N 5.5
Axial static force without shaft support, N 34
Max winding temperature, °F 257, 257
Thermal Resistance, °C/W No
Thermal Time Constant, °C/W 1100
Weight Oz 4.93
Rotor Inertia, gcm² 3.5
Typical Housing Material No
Hall Sensor Elecrical Phasing, electrical° 120
Motor Regulation R/k², 10³/Nms No
Company Portescap
