17VL015 - NEMA 17 Planetary Gearhead
The 17VL015 planetary gearhead offers true planetary performance in a value priced package. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
True Planetary Design
Compact Design
Sealed Ball Bearings
Heat Treated Gears
High Efficiency Design
AGMA Gear Quality
Company Applied Motion
Part Number 17vl015_nema_17_planetary_ge
Backlash 16 arc-min
Efficiency [%] 85%
Frame Size NEMA 17
Inertia 2.307E-04 oz-in-sec2
Input Speed 5000 RPM Max
IP Rating No
Low Backlash NA
Operating Temperature -40 to 120 C
Part Number 17VL015
Ratio 15:1
Service Life > 10,000 hours
Shaft Diameter 12.7 mm (0.500 inch)
Torque E Stop 224 in-lb
Torque Max Accel 138 in-lb
Torque Nominal 110 in-lb
