17VL010 - NEMA 17 Planetary Gearhead
The 17VL010 planetary gearhead offers true planetary performance in a value priced package. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
Available in 48 hour lead time
True planetary design
Compact design
Sealed ball bearings
Heat treated gears
High efficiency design
AGMA gear quality
Other ratios available in 2-4 week lead time: 4, 5, 7
Company Applied Motion
Part Number 17vl010_nema_17_planetary_ge
Backlash 12 arc-min
Efficiency [%] 90%
Frame Size NEMA 17
Inertia 1.395E-10 oz-in-sec2
Input Speed 5000 RPM Max
IP Rating IP54
Low Backlash NA
Operating Temperature -40 to 120 C
Part Number 17VL010
Ratio 10:1
Service Life > 10,000 hours
Shaft Diameter 12.7 mm (0.500 inch)
Torque E Stop 153 in-lb
Torque Max Accel 102 in-lb
Torque Nominal 81 in-lb
