17VL007 - NEMA 17 Planetary Gearhead
The 17VL007 planetary gearhead offers true planetary performance in a value priced package. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
True Planetary Design
Compact Design
Sealed Ball Bearings
Heat Treated Gears
High Efficiency Design
AGMA Gear Quality
Company Applied Motion
Part Number 17vl007_nema_17_planetary_ge
Backlash 12 arc-min
Efficiency [%] 90%
Frame Size NEMA 17
Inertia 1.566E-04 oz-in-sec2
Input Speed 5000 RPM Max
IP Rating No
Low Backlash NA
Operating Temperature -40 to 120 C
Part Number 17VL007
Ratio 7:1
Service Life > 10,000 hours
Shaft Diameter No
Torque E Stop 183 in-lb
Torque Max Accel 113 in-lb
Torque Nominal 90 in-lb
