17VL005 - NEMA 17 Planetary Gearhead
The 17VL005 planetary gearhead offers true planetary performance in a value priced package. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
True Planetary Design
Compact Design
Sealed Ball Bearings
Heat Treated Gears
High Efficiency Design
AGMA Gear Quality
# All torque ratings are based upon 3,000 rpm nominal input speed and 10,000 hours minimum service life.
# E-Stop torque rating is limited to 1,000 occurrences.
# Gearhead length based on NEMA motor mounting.
# Efficiency rated at 3,000 rpm input speed at Nominal Rated Torque.
# Gearhead inertia values shown include pinion, clamp, and sleeve, and are for standard NEMA mounting.
Company Applied Motion
Part Number 17vl005_nema_17_planetary_ge
Backlash 12 arc-min
Efficiency [%] 90%
Frame Size NEMA 17
Inertia 1.895E-04 oz-in-sec2
Input Speed 5000 rpm max
IP Rating IP54
Low Backlash NA
Operating Temperature -40 to 120 C
Part Number 17VL005
Ratio 5:1
Service Life >10,000 hours
Shaft Diameter 12.7 mm (0.500 inch)
Torque E Stop 210 in-lb
Torque Max Accel 130 in-lb
Torque Nominal 103 in-lb
