17PN016 - NEMA 17 Planetary Gearhead
The 17PN016 planetary gearhead offers true planetary performance, efficient transmission of torque, and accurate speed matching.
True planetary design
Low backlash design
Input pinion with balanced clamp collar
Quick installation
Strong, caged roller bearings
High efficiency design
All gears are heat treated
NEMA mounting standards
Company Applied Motion
Part Number 17pn016_nema_17_planetary_ge
Backlash 14 arc-min
Efficiency [%] 85%
Frame Size NEMA 17
Inertia 1.352E-04 oz-in-sec2
Input Speed 5000 rpm max
IP Rating No
Low Backlash 9 arc-min
Operating Temperature -50 to 120 C
Part Number 17PN016
Ratio 16:1
Service Life > 10,000 hours
Shaft Diameter 12.7 mm (0.500 inch)
Torque E Stop No
Torque Max Accel 176 in-lb
Torque Nominal 127 in-lb
