17PN010 - NEMA 17 Planetary Gearhead
The 17PN010 planetary gearhead offers true planetary performance, efficient transmission of torque, and accurate speed matching.
Available in 48 hour lead time
True planetary design
Low backlash design
Input pinion with balanced clamp collar
Quick installation
Strong, caged roller bearings
High efficiency design
All gears are heat treated
NEMA mounting standards
Other ratios available in 2-4 week lead time: 3, 4, 5, 5.5, 7
Company Applied Motion
Part Number 17pn010_nema_17_planetary_ge
Backlash 10 arc-min
Efficiency [%] 90%
Frame Size NEMA 17
Inertia 1.132E-04 oz-in-sec2
Input Speed 5000 rpm max
IP Rating No
Low Backlash 7 arc-min
Operating Temperature -50 to 120 C
Part Number 17PN010
Ratio 10:1
Service Life > 10,000 hours
Shaft Diameter 12.7 mm (0.500 inch)
Torque E Stop No
Torque Max Accel 84 in-lb
Torque Nominal 56 in-lb
