17PL010 - NEMA 17 Planetary Gearhead
The 17PL010 planetary gearhead offers true planetary performance in a high torque, low backlash design. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
2 day delivery
True planetary design
Low backlash design
High strength steels
High shaft loading capacity
Sealed ball bearings
Heat treated gears
High efficiency design
Other ratios available with 2-4 week lead times: 3, 4, 5, 5.5, 7
Output torque is rated at 3000 RPM, and a minimum life of 10,000 hours.
Bearing load ratings are based on a minimum life of 10,000 hours.
Company Applied Motion
Part Number 17pl010_nema_17_planetary_ge
Backlash 6 arc-min
Efficiency [%] 90%
Frame Size NEMA 17
Inertia 1.833E-05 oz-in-sec2
Input Speed 6500 rpm max
IP Rating No
Low Backlash 3 arc-min
Operating Temperature -50 to 120 C
Part Number 17PL010
Ratio 10:1
Service Life >10,000 hours
Shaft Diameter 12.7 mm (0.500 inch)
Torque E Stop No
Torque Max Accel 84 in-lb
Torque Nominal 56 in-lb
