17PL005.5 - NEMA 17 Planetary Gearhead
The 17PL005.5 planetary gearhead offers true planetary performance in a high torque, low backlash design. High strength, heated treated gears provide for efficient transmission of torque and accurate speed matching.
True planetary design
Low backlash design
High strength steels
High shaft loading capacity
Sealed ball bearings
Heat treated gears
High efficiency design
2-3 week lead time
Company Applied Motion
Part Number 17pl005_5_nema_17_planetary
Backlash 6 arc-min
Efficiency [%] 90%
Frame Size NEMA 17
Inertia 1.174E-04 oz-in-sec2
Input Speed 5000 rpm max
IP Rating No
Low Backlash 3 arc-min
Operating Temperature -50 to 120 C
Part Number 17PL005.5
Ratio 5.5:1
Service Life >10,000 hours
Shaft Diameter 12.7 mm (0.500 inch)
Torque E Stop No
Torque Max Accel 233 in-lb
Torque Nominal 143 in-lb
