16BHS 2A L .01
16BHS 2A L .01
The 16BHS brushless DC slotless motor utilizes a self-supporting cylindrical ironless coil made in the same winding technique as our ironless DC motors. The 16BHS miniature motor offers long life, excellent speed and position control and smooth rotation.
Integrated electronics
Slotless
2 poles
Compact design
Low iron losses at high speed
High efficiency
3 phases
Shaft lengths
Special coils
Cables and connectors
Special mounting holes pattern
Value addtion mounting
Part Number 16BHS2AL.01_slotless
Diameter, in 0.63
Length, in 1.27
Nominal Voltage, Volt 12.0
Optimization Speed No
No-Load Speed, rpm No
Typical No-Load Current, mA 75
Max continuous mechanical power (@ 25°C) No
Max continuous Current, A 0.4
Max Continuous Torque,oz-in 0.51
Back-EMF Constant, V/1000 rpm 0.84
Torque Constant, oz-in/A 1.15
Motor constant k/R½, oz-in/W½ 0.28
Internal resistance - phase to phase, Ohm 16.50
Line to Line resistance at connectors, Ohm No
Inductance - phase to phase, mH 0.66
Mechanical Time Constant, ms 13.2
Electrical time constant, ms 4.0
Max motor speed, rpm No
Ambient working temperature range, °F -0.125
Ambient storage temperature range, °F -0.227272727
Ball bearings preload, N 2.0
Axial static force without shaft support, N 25
Max winding temperature, °F 257, 257
Thermal Resistance, °C/W 22
Thermal Time Constant, °C/W 520
Weight Oz 1.16
Rotor Inertia, gcm² 0.5
Typical Housing Material No
Hall Sensor Elecrical Phasing, electrical° No
Motor Regulation R/k², 10³/Nms 251.50
Company Portescap
