U2700A Series
U2700A Series
$1,500.00
N/A
Company Keysight Instruments
Part Number u2700a_series
Bandwidth 100 MHz ~ 200 MHz
Max Sample Rate 1 GS/sec
Channels 2
Max Memory Depth 32 Mpts
Waveform Update Rate/Max Trigger Rate Depends on the operating system since it uses AMM software to display waveforms
Display size/Touch or non-touch screen no display (Uses the Measurement Manager, AMM to display waveforms.)
Vertical Resolution 8 bits
Instrument Integrations The dual-play capability permits standalone use or within U2781A chassis with other USB modular products to work as a modular system.
Trigger Modes Edge, pulse width, TV
Vertical Sensitivity Min 2 mV/div
Time Base Range 1 nsec/div to 50 sec/div
Time Scale Accuracy 20 ppm
Footprint 117 × 180 × 41 mm (with bumpers) / 105 × 175 × 25 mm (without bumpers)
Request Quotation
