TBS1000B-EDU
TBS1000B-EDU
$520.00
Waveform measurements: Cursors Types Amplitude, Time Measurements ΔT, 1/ΔT, ΔV Automatic measurements Period, Frequency, Pos Width, Neg Width, Rise Time, Fall Time, Maximum , Minimum , Peak-Peak, Mean, RMS, Cycle RMS, Cursor RMS, Phase, Pos Pulse Cnt, Neg Pulse Cnt, Rise Edge Cn, Fall Edge Cn, Pos Duty, Neg Duty, Amplitude, Cycle Mean, Cursor Mean, Burst Width, Pos Overshoot, Neg Overshoot, Area, Cycle Area, High, Low, Delay RR, Delay RF, Delay FR, Delay FF Waveform math Arithmetic Add, Subtract, Multiply Math functions FFT FFT Windows: Hanning, Flat Top, Rectangular 2048 sample points Sources Two channel models: CH1 - CH2, CH2 - CH1, CH1 + CH2, CH1 × CH2 Autoset Autoset menu Single-button, automatic setup of all channels for vertical, horizontal, and trigger systems, with undo Autoset Square wave Single Cycle, Multicycle, Rising or Falling Edge Sine wave Single Cycle, Multicycle, FFT Spectrum Video (NTSC, PAL, SECAM) Field: All, Odd, or Even Line: All or Selectable Line Number. Frequency counter signal source Pulse width or edge selected trigger source Frequency counter measures selected trigger source at all times in pulse width and edge mode, including when the oscilloscope acquisition is halted due to changes in run status, or acquisition of a single shot event has completed. The frequency counter does not measure pulses that do not qualify as legitimate trigger events. Pulse Width mode: Counts pulses of enough magnitude inside the 250 ms measurement window that qualify as triggerable events (e.g. all narrow pulses in a PWM pulse train if set to "<" mode and the limit is set to a relatively small number). Edge Trigger mode: Counts all pulses of enough magnitude.
Company Tektronix
Part Number tbs1000e_edu
Bandwidth 50-200 MHz
Max Sample Rate 2 GS/sec
Channels 2 analog
Max Memory Depth 2.5K
Waveform Update Rate/Max Trigger Rate Not Specified
Display size/Touch or non-touch screen 7 in. WVGA color display
Vertical Resolution 8 bits
Instrument Integrations Frequency counter
Trigger Modes Edge (Rising/Falling) Conventional level-driven trigger. Positive or negative slope on any channel. Coupling selections: AC, DC, Noise Reject, HF Reject, LF Reject; Video: Trigger on all lines or individual lines, odd/even or all fields from composite video, or broadcast standards (NTSC, PAL, SECAM); Pulse Width (or Glitch): Trigger on a pulse width less than, greater than, equal to, or not equal to, a selectable time limit ranging from 33 ns to 10 s
Vertical Sensitivity 2 mV to 5 V/div on all models with calibrated fine adjustment
Time Base Range 50 MHz and 70 MHz models 5 ns to 50 s/div; 100MHz, 150MHz and 200MHz Models 2.5 ns to 50 s/div
Time Scale Accuracy 50 ppm
Footprint 12.85 (W)× 6.22 (H)× 4.89 (D) in.
