NI PXIe-5170R and 5171R
$6,999.00
User-programmable with LabVIEW FPGA, Data-streaming of 3.2 GB/sec
Company National Instruments Inc.
Part Number ni_pxie_5170r_5171r
Bandwidth up to 250 MHz
Max Sample Rate 0.25 GS/sec
Channels 4 - 8
Max Memory Depth 1.5 GB or 750 Mpts
Waveform Update Rate/Max Trigger Rate No
Display size/Touch or non-touch screen Uses PC display
Vertical Resolution 14-bit
Instrument Integrations Can be integrated easily into Mixed Signal PXI system.
Trigger Modes User-programmable triggers with LabVIEW FPGA
Vertical Sensitivity 5 Vpp – 200 mVpp
Time Base Range 250 MHz
Time Scale Accuracy ±25 ppm
Footprint 3U, One slot, PXIe/cPCIe Module
Request Quotation
