NI PXI(e)-5105
NI PXI(e)-5105
$4,999.00
8 Simultaneously sampled channels w/ deep onboard memory
Company National Instruments Inc.
Part Number ni_pxie_5105
Bandwidth 60 MHz
Max Sample Rate 0.060 GS/sec
Channels 8
Max Memory Depth 512 MB or 256 Mpts
Waveform Update Rate/Max Trigger Rate 2.4 microseconds trigger rearm time
Display size/Touch or non-touch screen Uses PC display
Vertical Resolution 12-bit
Instrument Integrations Can be integrated easily into Mixed Signal PXI system.
Trigger Modes Edge, Window, Hysteresis, Digital, Immediate, Software
Vertical Sensitivity 30 Vpp – 50 mVpp
Time Base Range 915.5 S/sec to 60 MS/sec
Time Scale Accuracy ±25 ppm
Footprint 3U, One slot, PXI(e)/cPCI(e) Module
