NI PXI-5922
NI PXI-5922
$9,334.00
flexible oscilloscope with resolution modes from 16 to 24-bit, and maximum -120 dB FS rms noise
Company National Instruments Inc.
Part Number ni_pxi_5922
Bandwidth 6 MHz
Max Sample Rate 0.015 GS/sec
Channels 2
Max Memory Depth 256 MB or 85 Mpts
Waveform Update Rate/Max Trigger Rate 144 × Sample Clock period
Display size/Touch or non-touch screen Uses PC display
Vertical Resolution up to 24-bit
Instrument Integrations Can be integrated easily into Mixed Signal PXI system.
Trigger Modes Edge, Window, Hysteresis, Digital, Immediate, Software
Vertical Sensitivity 10 Vpp – 2 Vpp
Time Base Range 50 kS/sec to 15 MS/sec
Time Scale Accuracy ±50 ppm, typical
Footprint 3U, One slot, PXI/cPCI Module
