MSO/DPO2000B
MSO/DPO2000B
$1,290.00
Waveform measurements: Cursors Waveform and Screen. Automatic measurements 29, of which up to four can be displayed on-screen at any one time. Measurements include: Period, Frequency, Delay, Rise Time, Fall Time, Positive Duty Cycle, Negative Duty Cycle, Positive Pulse Width, Negative Pulse Width, Burst Width, Phase, Positive Overshoot, Negative Overshoot, Peak to Peak, Amplitude, High, Low, Max, Min, Mean, Cycle Mean, RMS, Cycle RMS, Positive Pulse Count, Negative Pulse Count, Rising Edge Count, Falling Edge Count, Area and Cycle Area. Gating Isolate the specific occurrence within an acquisition to take measurements on, using either the screen, or waveform cursors. Waveform math Arithmetic Add, subtract, and multiply waveforms. FFT Spectral magnitude. Set FFT Vertical Scale to Linear RMS or dBV RMS, and FFT Window to Rectangular, Hamming, Hanning, or Blackman-Harris.
Company Tektronix
Part Number mso_dpo_2000b
Bandwidth 70-200 MHz
Max Sample Rate 1 GS/sec
Channels 4 analog; 16 digital
Max Memory Depth 1 M
Waveform Update Rate/Max Trigger Rate 5,000 wfms/sec
Display size/Touch or non-touch screen 7 in. WQVGA color display; DB-15
Vertical Resolution 8 bits
Instrument Integrations 16-channel logic analyzer
Trigger Modes Edge Positive or negative slope on any channel or front-panel auxiliary input. Coupling includes DC, AC, HF reject, LF reject, and noise reject. Pulse Width Trigger on width of positive or negative pulses that are >, <, =, ≠, or inside/outside a specified period of time. Runt Trigger on a pulse that crosses one threshold but fails to cross a second threshold before crossing the first again. Logic Trigger when any logical pattern of channels goes false or stays true for specified period of time. Any input can be used as a clock to look for the pattern on a clock edge. Pattern (AND, NAND) specified for all input channels defined as High, Low, or Don’t Care. Setup and Hold Trigger on violations of both setup time and hold time between clock and data present on any of the analog and digital input channels. Rise/Fall Time Trigger on pulse edge rates that are faster or slower than specified. Slope may be positive, negative, or either. Video Trigger on all lines, odd, even, or all fields on NTSC, PAL, and SECAM video signals. I2C (optional) Trigger on Start, Repeated Start, Stop, Missing ACK, Address (7 or 10 bit), Data, or Address and Data on I2C buses up to 3.4 Mb/ s. SPI (optional) Trigger on SS, MOSI, MISO, or MOSI and MISO on SPI buses up to 10.0 Mb/s. RS-232/422/485/UART (optional) Trigger on Tx Start Bit, Rx Start Bit, Tx End of Packet, Rx End of Packet, Tx Data, Rx Data, Tx Parity Error, and Rx Parity Error up to 10 Mb/s. CAN (optional) Trigger on Start of Frame, Frame Type (data, remote, error, overload), Identifier (standard or extended), Data, Identifier and Data, End of Frame, Missing ACK, or Bit Stuffing Error on CAN signals up to 1 Mb/s. Data can be further specified to trigger on ≤, <, =, >, ≥, or ≠ a specific data value. User-adjustable sample point is set to 50% by default. LIN (optional) Trigger on Sync, Identifier, Data, Identifier and Data, Wakeup Frame, Sleep Frame, Errors such as Sync, Parity, or Checksum Errors. Parallel (available on MSO models only) Trigger on a parallel bus data value.
Vertical Sensitivity 2 mV/div to 5 V/div
Time Base Range 200 MHz models: 2ns to 100s; 70, 100 MHz models: 4ns to 100s
Time Scale Accuracy ±25 ppm over any ≥1 ms interval
Footprint 4U, 14.9 (W) x 7.1 (H) x 5.3 (D) in.
