InfiniiVision 6000 X-Series
$14,930.00
Jitter, Real time eye analysis / clock recovery, protocol trigger and decode
Company Keysight Instruments
Part Number iv_6000_x_series
Bandwidth 1.0 ~ 6.0 GHz
Max Sample Rate 20 GS/sec
Channels 2 or 4 + 16
Max Memory Depth 4 Mpts
Waveform Update Rate/Max Trigger Rate > 450,000 wfms/sec
Display size/Touch or non-touch screen 12.1-in. capacitive multi-touch
Vertical Resolution 8 bit (12 bit in high res mode)
Instrument Integrations digital timing, protocol analysis, dual arbitrary function generator, DVM, 10 digit counter. Histogram
Trigger Modes Zone, edge, edge then edge, pulse width, runt, setup/hold, rise/fall time, Nth edge burst, pattern, or, video, protocols
Vertical Sensitivity 1 mV ~ 5 V/div
Time Base Range 100 psec to 50 sec/div
Time Scale Accuracy 1.6 ppm
Footprint 425 (W) × 288 (H)× 148 (D) mm
