InfiniiVision 4000 X-Series
$7.81
Protocol trigger and decode
Company Keysight Instruments
Part Number iv_4000_x_series
Bandwidth 200 MHz ~ 1.5 GHz
Max Sample Rate 5 GS/sec
Channels 2 or 4 + 16
Max Memory Depth 4 Mpts
Waveform Update Rate/Max Trigger Rate > 1,000,000 wfms/sec
Display size/Touch or non-touch screen 12.1-in. capacitive touch
Vertical Resolution 8 bit (12 bit in high res mode)
Instrument Integrations digital timing, protocol analysis, dual arbitrary function generator, DVM
Trigger Modes Zone, edge, edge then edge, pulse width, runt, setup/hold, rise/fall time, Nth edge burst, pattern, or, video, protocols
Vertical Sensitivity 1 mV ~ 5 V/div
Time Base Range 500 psec to 50 sec/div
Time Scale Accuracy 10 ppm
Footprint 454 (W) × 275 (H) × 156 (D) mm
Request Quotation
