Infiniium Z-Series
Infiniium Z-Series
$221.76
Multiscope, cable/probe loss correction, compliance apps
Company Keysight Instruments
Part Number Infiniium_Z_Series
Bandwidth 20 ~ 63 GHz
Max Sample Rate 160 GS/sec
Channels 2~4
Max Memory Depth 2 Gpts
Waveform Update Rate/Max Trigger Rate > 400,000 wfms/sec
Display size/Touch or non-touch screen 15.4-in. capacitive multi-touch
Vertical Resolution 8 bit (12 bit in high res mode)
Instrument Integrations digital timing, protocol decoder
Trigger Modes Edge, edge transition, edge then edge, glitch, pulse width, runt, timeout, pattern, state, setup and hold, window, Gbit serial, video, zone qualify, generic serial, measurement limit, non-monotonic edge, runt, protocol
Vertical Sensitivity 1 mV/div ~ 1 V/div
Time Base Range 2 psec/div ~ 20 sec/div
Time Scale Accuracy 0.1 ppm
Footprint 436 (W) × 266 (H) × 492(D) mm
Request Quotation
