Infiniium S-Series
Infiniium S-Series
$17,534.00
Power rail analysis, digital channels, multiscope, compliance apps
Company Keysight Instruments
Part Number i_s_series
Bandwidth 500 MHz ~ 8 GHz
Max Sample Rate 20 GS/sec
Channels 4 + 16
Max Memory Depth 800 Mpts
Waveform Update Rate/Max Trigger Rate > 250,000 wfms/sec
Display size/Touch or non-touch screen 15-in. capacitive multi-touch
Vertical Resolution 10 bit (12 bit in high res mode)
Instrument Integrations digital timing, protocol decoder
Trigger Modes Edge, edge transition, edge then edge, glitch, pulse width, runt, timeout, pattern, state, setup and hold, window, video, zone qualify, generic serial, measurement limit, non-monotonic edge, runt, protocol
Vertical Sensitivity 1 mV/div ~ 5 V/div
Time Base Range 5 psec/div ~ 20 sec/div
Time Scale Accuracy 0.012 ppm
Footprint 430 (W) × 330 (H)× 230 (D) mm
Request Quotation
