Infiniium 9000A Series
$17,000.00
Digital channels, multiscope, compliance apps
Company Keysight Instruments
Part Number i_9000a_series
Bandwidth 600 MHz ~ 4 GHz
Max Sample Rate 10 GS/sec
Channels 4 + 16
Max Memory Depth 1 Gpts
Waveform Update Rate/Max Trigger Rate > 250,000 wfms/sec
Display size/Touch or non-touch screen 15-in. resistive touch
Vertical Resolution 8 bit (12 bit in high res mode)
Instrument Integrations digital timing, protocol decoder
Trigger Modes Edge, edge transition, edge then edge, glitch, pulse width, runt, timeout, pattern, state, setup and hold, window, video, zone qualify, generic serial, measurement limit, non-monotonic edge, runt, protocol
Vertical Sensitivity 1 mV/div ~ 5 V/div
Time Base Range 5 psec/div ~ 20 sec/div
Time Scale Accuracy 0.4 ppm
Footprint 430 (W) × 330 (H)× 230 (D) mm
Request Quotation
