DPO7000C Series
DPO7000C Series
$18,800.00
Search and Mark Events Use Advanced Search and Mark to automatically mark events and document waveforms. Search positive/negative slopes or both, glitches, runts, pulse widths, transition rate, setup and hold, timeout, windows, or find any logic or state pattern, up to 8 different event types on any of the 4 analog channels. Search DDR Read or Write bursts with Opt. DDRA.; When an event of interest is found with a hardware trigger, other similar events can be found using "Mark All Trigger Events in Record" in the Pinpoint trigger control windows; The Event table summarizes all found events. All events are time stamped in reference to trigger position. You can choose to stop acquisitions when an event is found. Waveform measurements: Cursors Waveform and Screen, Automatic measurements 53, of which 8 can be displayed on-screen at any one time; Measurement Statistics Mean, Minimum, Maximum, Standard Deviation; Reference Levels User-definable reference levels for automatic measurements can be specified in either percent or units; Gating: Isolate the specific occurrence within an acquisition to take measurements on, using either screen or waveform cursors; Amplitude related: Amplitude, High, Low, Maximum, Minimum, Peak-to-Peak, Mean, Cycle Mean, RMS, Cycle RMS, Positive Overshoot, Negative Overshoot; Time related: Rise Time, Fall Time, Positive Width, Negative Width, Positive Duty Cycle, Negative Duty Cycle, Period, Frequency, Delay; Combination: Area, Cycle Area, Phase, Burst Width; Histogram related: Waveform Count, Hits in Box, Peak Hits, Median, Maximum, Minimum, Peak-to-Peak, Mean (μ), Standard Deviation (sigma), μ +1sigma, μ+2sigma, μ+3sigma; Eye-pattern related: Extinction Ratio (absolute, %, dB), Eye Height, Eye Width, Eye Top, Eye Base, Crossing %, Jitter (p-p, RMS, 6sigma), Noise (p-p, RMS), Signal/Noise Ratio, Cycle Distortion, Q-Factor; Waveform Histograms: A waveform histogram provides an array of data values representing the total number of hits inside a user-defined region of the display. A waveform histogram is both a visual graph of the hit distribution and a numeric array of values that can be measured; Sources – Channel 1, Channel 2, Channel 3, Channel 4, Ref 1, Ref 2, Ref 3, Ref 4, Math 1, Math 2, Math 3, Math 4; Types – Vertical, Horizontal. Waveform processing/math: Number of Math Waveforms Up to 4; Arithmetic Add, Subtract, Multiply, Divide Waveforms and Scalars; Algebraic expressions: Define extensive algebraic expressions including waveforms, scalars, user-adjustable variables, and results of parametric measurements. Perform math on math using complex equations. e.g. (Integral (CH1 – Mean(CH1)) × 1.414 × VAR1); Math functions: Average, Invert, Integrate, Differentiate, Square Root, Exponential, Log 10, Log e, Abs, Ceiling, Floor, Min, Max, Sin, Cos, Tan, ASin, ACos, ATan, Sinh, Cosh, Tanh; Relational: Boolean result of comparison >, <, ≥, ≤, ==, !=; Frequency domain functions: Spectral Magnitude and Phase, Real and Imaginary Spectra; FFT vertical units: Magnitude: Linear, dB, dBm Phase: Degrees, radians, group delay; FFT window functions: Rectangular, Hamming, Hanning, Kaiser-Bessel, Blackman-Harris, Gaussian, Flattop2, Tek Exponential; Waveform definition: As an arbitrary math expression; Filtering function: User-definable filters. Users specify a file containing the coefficients of the filter. Several example filter files are provided; Customized Functions using Math Plug-in Interface: An interface is provided to allow users to create their own custom math functions in MATLAB or Visual Studio; Mask function: Generates a Waveform Database pixel map from a sample waveform. Sample count can be defined.
Company Tektronix
Part Number dpo7000c_series
Bandwidth 500 MHz - 3.5 GHz
Max Sample Rate 40 GS/sec
Channels 4 analog
Max Memory Depth 500M Points
Waveform Update Rate/Max Trigger Rate 250,000 wfms/sec
Display size/Touch or non-touch screen 12.1 in. XGA color, touchscreen display; DVI-I and VGA
Vertical Resolution 8 bits (>11 bits with Hi Res)
Instrument Integrations No
Trigger Modes A Event and Delayed B Event trigger types: edge, glitch, width, runt, timeout, transition time, logic pattern, logic state, setup/hold, window - all except Edge, Pattern, and State can be Logic State qualified by up to two channels. Edge Positive, negative, or either slope on any channel or front-panel auxiliary input. Coupling includes DC, AC, noise reject, HF reject, and LF reject. Glitch Trigger on or reject glitches of positive, negative, or either polarity. Minimum glitch width is 170 ps (typical) with rearm time of 250 ps (for DPO7254C or DPO7354C). Width Trigger on width of positive or negative pulse either within or outside selectable limits (225 ps to 10 s). Runt Trigger on a pulse that crosses one threshold but fails to cross a second threshold before crossing the first again. Event can be time- or logic-qualified. Window Trigger on an event that enters or exits a window defined by two user-adjustable thresholds. Event can be time or logic qualified. Timeout Trigger on an event which remains high, low, or either, for a specified time period (300 ps to 1 s). Transition Trigger on pulse edge rates that are faster or slower than specified. Slope may be positive, negative, or either. Setup/Hold Trigger on violations of both setup time and hold time between clock and data present on any two input channels. Logic Pattern Trigger when pattern goes false or stays true for specified period of time (300 ps to 1 s). Pattern (AND, OR, NAND, NOR) specified for all analog input channels defined as high, low, or don’t care. Logic State Any logical pattern of channels (1, 2, 3) clocked by edge on channel 4. Trigger on rising or falling clock edge. Parallel Bus Trigger on specified data value on defined parallel bus. Video Trigger on all lines, specific line number, odd, even, or all fields on NTSC, PAL, SECAM, and HDTV 480p/60, 576p/50, 875i/60, 720p/30, 720p/50, 720p/60, 1080/24sF, 1080i/50, 1080p/25, 1080i/60, 1080p/24, 1080p/25, 1080p/50, 1080p/60, Bi-level, Tri-level. Visual Trigger Trigger on up to 8 user-specified areas, including rectangle, triangle, trapezoid, hexagon, and user-specified shapes on any of the analog channels. Serial Pattern Captures serial data stream with built-in clock recovery for NRZ standards up to 1.25 Gb/s. Extended with pattern lock triggering to capture repeated acquisitions of long serial data patterns. Provided as part of Opt. ST1G. Comm Support for AMI, HDB3, BnZS, CMI, MLT3, and NRZ encoded signals. Provided as part of Option MTM. I2C Trigger on Start, Repeated Start, Stop, Missing ACK, Address (7 or 10 bit), Data (1-5 bytes), or Address and Data on I2C buses up to 10 Mb/s. Provided as part of Opt. SR-EMBD. SPI Trigger on Slave Select, Idle Time, or Data (1-6 words) on SPI buses up to 10 Mb/s. Provided as part of Opt. SR-EMBD. CAN Trigger on Start of Frame, Frame Type (Data, Remote, Error, or Overload), Identifier, Data, Identifier and Data, End of Frame, Missing Ack, Bit Stuff Error or CRC Error on CAN buses up to 1 Mb/s. Provided as part of Opt. SR-AUTO. LIN Trigger on Sync, Identifier, Data, Ident and Data, Wakeup Frame, Sleep Frame, and Error on LIN buses up to 1 Mb/s. Provided as part of Opt. SR-AUTO. FlexRay Trigger on Indicator Bits (Normal, Payload, Null, Sync, Startup), Cycle Count, Header Fields (Indicator Bits, Identifier, Payload Length, Header CRC, and Cycle Count), Identifier, Data, Identifier and Data, End Of Frame, and Error on FlexRay buses up to 10 Mb/s. Provided as part of Opt. SR-AUTO. MIL-STD-1553B Trigger on Sync, Command Word, Status Word, Data Word, Idle Time, and Error on MIL-STD-1553 buses up to 1 Mb/s. Provided as part of Opt. SR-AERO. RS-232/422/485/UART Trigger on Start Bit, End of Packet, Data (1-5 words), and Parity Error on RS-232 buses up to 10 Mb/s. Provided as part of Opt. SR-COMP. USB 2.0 Low speed Trigger on Sync, Reset, Suspend, Resume, End of Packet, Token (Address) Packet, Data Packet, Handshake Packet, Special Packet, Error. Provided as part of Opt. SR-USB. Token Packet Trigger – Any token type, SOF, OUT, IN, SETUP; Address can be specified for Any, OUT, IN, and SETUP token types. Address can be further specified to trigger on ≤, <, =, >, ≥, != a particular value, or inside or outside a range. Frame number can be specified for SOF token using Binary, Hex, Unsigned Decimal, and Don't Care digits. Data Packet Trigger – Any data type, DATA0, DATA1; Data can be further specified to trigger on ≤, <, =, >, ≥, != a particular data value, or inside or outside of a range. Handshake Packet Trigger – Any handshake type, ACK, NAK, STALL. Special Packet Trigger – Any special type, Reserved. Error Trigger – PID Check, CRC5 or CRC16, Bit Stuffing. USB 2.0 Full speed Trigger on Sync, Reset, Suspend, Resume, End of Packet, Token (Address) Packet, Data Packet, Handshake Packet, Special Packet, Error. Provided as part of Opt. SR-USB. Token Packet Trigger – Any token type, SOF, OUT, IN, SETUP; Address can be specified for Any, OUT, IN, and SETUP token types. Address can be further specified to trigger on ≤, <, =, >, ≥, != a particular value, or inside or outside a range. Frame number can be specified for SOF token using Binary, Hex, Unsigned Decimal, and Don't Care digits. Data Packet Trigger – Any data type, DATA0, DATA1; Data can be further specified to trigger on ≤, <, =, >, ≥, != a particular data value, or inside or outside a range. Handshake Packet Trigger – Any handshake type, ACK, NAK, STALL. Special Packet Trigger – Any special type, PRE, Reserved. Error Trigger – PID Check, CRC5 or CRC16, Bit Stuffing. USB 2.0 High speed No protocol-level triggering. Provided as part of Opt. SR-USB.
Vertical Sensitivity 1 MΩ: 1 mV/div to 10 V/div 50 Ω: 1 mV/div to 1 V/div
Time Base Range 1.25 ps/div to 1000 s/div
Time Scale Accuracy ±2.5 ppm + aging <1 ppm per year
Footprint 11.48 (H) x 17.75 (W) x 10.44 (D)
