BK2/15/59
BK2/15/59
$0.00
Design
With a single radial clamping screw per hub ISO 4762. Any imbalance of the clamping hubs is compensated for by balancing bores located on the inside of the hub.
Temperature range
-30° C bis +100° C (-22° F to +212° F)
Backlash
Absolutely backlash-free due to frictional clamp connection.
Service life
These couplings are maintenance-free if the technical ratings are not exceeded.
Tolerance
On the hub/shaft connection 0.01 to 0.05 mm.
Material
Bellows made of highly flexible high-grade stain-less steel, hub material: see table below.
Brief overloads
Acceptable up to 1.5 times the value specified.
Speeds
Up to 10,000 rpm, in excess of 10,000 available with a finely balanced version.
Non-standard application
Custom designs with varied tolerances, keyways, non-standard material, bellows and ATEX designs are available upon request.
  • easy to mount
  • suited for space restricted installations
  • low moment of inertia
Company R+W Coupling Technology
Part Number BK2/15/59
Download Specification Request Quotation
