6000L Series
6000L Series
$8.40
Protocol trigger and decode
Company Keysight Instruments
Part Number 6000l_series
Bandwidth 100 MHz ~ 1.0 GHz
Max Sample Rate 4 GS/sec
Channels 4
Max Memory Depth 8 Mpts
Waveform Update Rate/Max Trigger Rate > 100,000 wfms/sec
Display size/Touch or non-touch screen N/A
Vertical Resolution 8 bit (12 bit in high res mode)
Instrument Integrations protocol analysis
Trigger Modes Edge, pulse width, pattern, video, duration, sequence, protocols
Vertical Sensitivity 1 mV ~ 5 V/div
Time Base Range 500 ps to 50 sec/div
Time Scale Accuracy 15 ppm
Footprint 435 (W)× 420 (H) × 270 (D) mm
Request Quotation
