6000 Series
6000 Series
$5,880.00
Record & Analyze mode, Pass/Fail, FFT, Serial Decode Options, auto cursors and measurements
Company Rigol
Part Number 6000_series
Bandwidth 600 MHz - 1 GHz
Max Sample Rate 5 GS/sec
Channels 2 or 4 analog
Max Memory Depth 140 Mpts
Waveform Update Rate/Max Trigger Rate Not specified
Display size/Touch or non-touch screen 10.1-in. WVGA non-touch
Vertical Resolution 8 bit (>10 in high res mode)
Instrument Integrations No
Trigger Modes Edge, Pulse, Slope, Video, Pattern, RS232, I2C, SPI, CAN, FlexRay, USB
Vertical Sensitivity 2 mV/div to 5 V/div
Time Base Range 500 psec/div to 1,000 sec/div (1 GHz models)
Time Scale Accuracy 4 ppm
Footprint 399.0 (W) × 255.3 (H) × 123.8 (D) mm
