4000 Series
4000 Series
$1,999.00
Record & Analyze mode, Pass/Fail, FFT, Serial Decode Options, auto cursors and measurements
Company Rigol
Part Number 4000_series
Bandwidth 100-500 MHz
Max Sample Rate 4 GS/sec
Channels 2 or 4 analog + 16 digital (MSO models)
Max Memory Depth 140 Mpts
Waveform Update Rate/Max Trigger Rate Not specified
Display size/Touch or non-touch screen 9-in. WVGA non-touch
Vertical Resolution 8 bit (>10 in high res mode)
Instrument Integrations 16-channel Logic in MSO models
Trigger Modes Edge, Pulse, Slope, Video, Runt, Nth edge, RS-232, I2C, SPI, CAN, Flexray, USB, Pattern, Duration (some are options)
Vertical Sensitivity 1 mV/div to 5 V/div
Time Base Range 1 nsec/div – 1,000 sec/div (500 MHz models)
Time Scale Accuracy 4 ppm
Footprint 440 (W) × 218 (H) × 130 (D) mm
