2000A Series
2000A Series
$839.00
Record & Analyze mode, Pass/Fail, FFT, Serial Decode Options, auto cursors and measurements
Company Rigol
Part Number 2000a_series
Bandwidth 70-300 MHz
Max Sample Rate 2 GS/sec
Channels 2 analog + 16 digital (MSO models)
Max Memory Depth 14 Mpts std; 56 Mpts option
Waveform Update Rate/Max Trigger Rate Not specified
Display size/Touch or non-touch screen 8-in. WVGA non-touch
Vertical Resolution 8 bit (>10 in high res mode)
Instrument Integrations 16-channel Logic in MSO models; 2-channel function generator in "-S" models
Trigger Modes Edge, Pulse, Slope, Video, Runt, Setup/Hold, Pattern, RS-232, I2C, SPI (std); Window, Delay, Duration,Nth edge,Timeout, CAN (options)
Vertical Sensitivity 500 μV/div to 10 V/div
Time Base Range 1 nsec/div – 1,000 sec/div
Time Scale Accuracy 25 ppm
Footprint 361.6 (W) × 179.6 (H) × 130.8 (D) mm
