1000Z Series
1000Z Series
$399.00
Record mode (option), Pass/Fail, FFT, auto cursors and measurements
Company Rigol
Part Number 1000z_series
Bandwidth 50-100 MHz
Max Sample Rate 1 GS/sec
Channels 4 analog; 16 digital (MSO models)
Max Memory Depth 12 Mpts std; 24 Mpts option
Waveform Update Rate/Max Trigger Rate Not specified
Display size/Touch or non-touch screen 7-in. WVGA non-touch
Vertical Resolution 8 bit (>10 in high res mode)
Instrument Integrations 16-channel Logic in MSO models; 2-channel function generator in "-S" models
Trigger Modes Edge, Pulse, Slope, Video, Timeout, Runt, Window, Delay, Setup/Hold, Nth edge, RS-232, I2C, SPI; Pattern, Duration (some are options)
Vertical Sensitivity 1 mV/div to 10 V/div
Time Base Range 5 nsec/div to 50 sec/div
Time Scale Accuracy 25 ppm
Footprint 313.1 (W) × 160.8 (H) × 122.4 (D) mm
Request Quotation
